[winGRASS] Problem with wish command
    Bryan Keith
    bryan at geomega.com
    Tue Oct  3 10:54:20 EDT 2006
Helmut,
I also had that problem, and I believe I got around that error by
changing some lines in grass.bat.  Here's what I have for lines 5-8:
set STARTUP_DIR=C:\msys\1.0
set PATH=%PATH%;C:\Program Files\PostgreSQL\8.1\bin;C:\MinGW\bin
set GRASS=grass
set GRASS_WISH=wish84.exe
However, after making that change, I still had problems getting GRASS to
start (see messages from the last ~2 weeks).  Maybe you'll be able to
get further along.
Bryan
Helmut Muenzing wrote:
> Hello,
> I just installed the native WinGRASS without any problem. However when I
> start GRASS the following message comes up:
> Warning: The wish command does not work as expected!
> Please check your GRASS_WISH environment variable.
> Use the -help option for details.
> Switching to text based interface mode.
> Hit return to continue.
> This does not tell me much.
> In grass.bat, there is a line <set GRASS_WISH=wish84>.
> What shall I do?
> Regards
> Helmut Muenzing
> hmc at sflu.com
> winGRASS mailing list
> winGRASS at grass.itc.it
> http://grass.itc.it/mailman/listinfo/wingrass
More information about the grass-windows
