[winGRASS] Problem with wish command - solved;
Problem with start-up skript
Helmut Muenzing
hmc at sflu.com
Tue Oct 3 21:32:56 EDT 2006
Thanks Bryan.
That helped so far. The wish environment seems to be in order now, but I
encountered the script error, probably the same as you did before. And I
have no idea of how to get around this.
Any help would be highly appreciated.
Regards
Helmut Muenzing
hmc at sflu.com
-----Original Message-----
Sent: Tuesday, October 03, 2006 22:54
To: hmc at sflu.com
Cc: wingrass at grass.itc.it
Subject: Re: [winGRASS] Problem with wish command
Helmut,
I also had that problem, and I believe I got around that error by
changing some lines in grass.bat. Here's what I have for lines 5-8:
set STARTUP_DIR=C:\msys\1.0
set PATH=%PATH%;C:\Program Files\PostgreSQL\8.1\bin;C:\MinGW\bin
set GRASS=grass
set GRASS_WISH=wish84.exe
However, after making that change, I still had problems getting GRASS to
start (see messages from the last ~2 weeks). Maybe you'll be able to
get further along.
Bryan
Helmut Muenzing wrote:
> Hello,
> I just installed the native WinGRASS without any problem. However when I
> start GRASS the following message comes up:
> Warning: The wish command does not work as expected!
> Please check your GRASS_WISH environment variable.
> Use the -help option for details.
> Switching to text based interface mode.
> Hit return to continue.
> This does not tell me much.
> In grass.bat, there is a line <set GRASS_WISH=wish84>.
> What shall I do?
> Regards
> Helmut Muenzing
> hmc at sflu.com
> winGRASS mailing list
> winGRASS at grass.itc.it
> http://grass.itc.it/mailman/listinfo/wingrass
__________ NOD32 1.1788 (20061003) Information __________
This message was checked by NOD32 antivirus system.
http://www.eset.com
More information about the grass-windows
