[winGRASS] Re: [GRASS-user] winGRASS 6.2.2 and 6.3.cvs
    Luigi Ponti
    lponti at infinito.it
    Sat Aug 18 08:51:23 EDT 2007
Ted Nebitko wrote:
> Native winGRASS 6.3.cvs (wingrass63_cvs20070801, 01-Aug-2007).
> I get the following error in the start-up script after pressing "enter
> grass" on placing location and mapset numbers in the opening gui
> (using grass63.bat)
> ERROR: program 'g.gisenv' cannot be executed because: Neither a
> command line (cmd) or interactive (inter) version was found.
> mail: not found while executing "exec g-gisenv get=GISDBASE" invoked
> from within
> "set env(GISDBASE) [exec g.gisenv get=GISDBASE]"
> (file "d:/grass/grass-6.3.cvs\etc\gm\gm.tcl" line31)
> Were you able to start this native wingrass version without problems?
Yes Ted,
It worked fine for me.
I noticed that you have the grass folder in D:\. The only thing I can
think of is the advice included in the README file
http://moritz.homelinux.org/grass/wingrass/README, which says "You might
want to uncomment and adapt some of the environment variables in
grass/bin/grass63.bat, notably WINGISBASE if you did not unzip the
package it in C:\". But off course you already took care of that.
Regards,
Luigi
>     ----- Original Message -----
>     *From:* Luigi Ponti <mailto:lponti at infinito.it>
>     *To:* grassuser at grass.itc.it <mailto:grassuser at grass.itc.it>
>     *Cc:* wingrass at grass.itc.it <mailto:wingrass at grass.itc.it>
>     *Sent:* Thursday, August 16, 2007 11:19 AM
>     *Subject:* [GRASS-user] winGRASS 6.2.2 and 6.3.cvs
>     Dear list,
>     On my MS Window XP machine, I have:
>     - Cygwin GRASS 6.1.cvs (last Huidae Cho's version);
>     - Cygwin GRASS 6.2.2-1 (18-Jul-2007);
>     - Native winGRASS 6.3.cvs (wingrass63_cvs20070801, 01-Aug-2007).
>     Some observations:
>     The three do not interfere with each other, except for the native
>     winGRASS 6.3.cvs that needs to reset GISDBASE: in ~/.grassrc6 to
>     an absolute path at startup (c:\cygwin\home\$USER\ as opposed to
>     \home\$USER\ which is enough for Cygwin): next time you use a
>     Cygwin version, it complains that it does not find the database
>     folder (and vice versa when you use start the native version after
>     a Cygwin/GRASS session). I understand one is very likely to
>     survive this inconvenience, but is there a way around it?
>     If I use the cygwin_grass.bat script to start GRASS 6.2.2-1 as
>     described at <http://grass.itc.it/grass62/binary/mswindows/#icon>,
>     I receive the error message:
>         Application initialization failed: this isn't a Tk
>         applicationcouldn't connect to display "127.0.0.1:0.0"
>         Error in startup script: dynamic loading is not currently
>         available on this system
>             while executing
>         "load /usr/local/lib/tk8.4/../libtk8.4.a Tk"
>             ("package ifneeded" script)
>             invoked from within
>         "package require Tk 8.0"
>             invoked from within
>         "package require -exact BWidget 1.2.1"
>             (file "/usr/local/grass-6.2.2/etc/gtcltk/options.tcl" line 15)
>             invoked from within
>         "source $env(GISBASE)/etc/gtcltk/options.tcl"
>             (file "/usr/local/grass-6.2.2/etc/gis_set.tcl" line 29)
>             while executing
>             invoked from within
>             invoked from within
>             (file "/usr/local/grass-6.2.2/etc/gm/gm.tcl" line 24)
>     However, if I use a modified grass.bat script (the one that starts
>     GRASS 6.1.cvs, only with grass62 instead of grass61 in the "run
>     xterm ..." line) everything works fine.The cygwin_grass.bat script
>     only works if there is an Cygwin/X Server already running from a
>     previous Cygwin/GRASS session (the Cygwin/X Server stays on after
>     exiting GRASS -- you have to manually shut it down). It sounds
>     like grass62 starts before startx has finished, but this is just
>     my impression. Is there a known fix to this? I have found no
>     answer in email archives.
>     Last thing: I have tried to run a shell script on the native
>     winGRASS 6.3.cvs (by typing the script name at the bottom box of
>     "Output - GIS.m" window and then pressing the different "run"
>     buttons) but it always fails (the script works fine on
>     Cygwin/GRASS versions) saying:
>     - nothing if I press "Run";
>     - nothing if I press "Run (Background)";
>     - error message if I press "Run UI":
>         couldn't execute "ita.sh": no such file or directory
>             while executing
>         "exec -- $program --tcltk"
>             (procedure "run_ui" line 6)
>             invoked from within
>         "run_ui [string trim [.gronsole.win.text get 1.0 end]]"
>             invoked from within
>         ".gronsole.command.runui invoke"
>             ("uplevel" body line 1)
>             invoked from within
>         "uplevel #0 [list $w invoke]"
>             (procedure "tk::ButtonUp" line 24)
>             invoked from within
>         "tk::ButtonUp .gronsole.command.runui
>             (command bound to event)
>     - if I press "Run in Xterm", a Windows command prompt flashes
>     briefly and then disappears.
>     At first I thought it was a matter of end of line characters,
>     since I noticed that the shell scripts of the native 6.3.cvs
>     version included in the "scripts" folder had CR/LF end of line
>     (and they seem to work if invoked in the way I described above for
>     my own script), while the Cygwin version of the same scripts had
>     LF end of line. But after converting end of lines to CR/LF, I get
>     the same results as described above when I tried to run the
>     script. Any hints on how try running homemade scripts on native
>     winGRASS?
>     Thanks and regards,
>     Luigi
>     _______________________________________________
>     grassuser mailing list
>     http://grass.itc.it/mailman/listinfo/grassuser
URL: http://lists.osgeo.org/pipermail/grass-windows/attachments/20070818/0ad7038f/attachment.html
More information about the grass-windows
