[winGRASS] Running MS Windows GRASS 6.3
Moritz Lennert
mlennert at club.worldonline.be
Mon Jun 4 04:16:55 EDT 2007
On 02/06/07 22:20, Kuba Z. wrote:
> I've unzipped Grass6.3 to c://grass (so it doesn't have spaces in
> directory names) and installed the software mentioned in
> http://moritz.homelinux.org/grass/wingrass/README instruction
> (ActiveState Tcl, Msys).
> I tried to run Grass and it looked like nothing had happened.
Could you be more specific ? How did you run GRASS ? What do you mean by
'nothing had happened' ?
You can try to run GRASS from the command line. Launch cmd.exe (From the
start menu chose 'Execute' or 'Run' and type cmd.exe). Then type
c:\grass\bin\grass63.bat -> Enter and then see what happens.
> I also
> tried to run ActiveState Tcl, Msys and start Grass after but the effect
> was the same.
You do not need to 'run' these before starting GRASS.
> I'm using Win XP. What may be the reason?
We will need more precise information to be able to help you.
Moritz
More information about the grass-windows
