[winGRASS] m.in.e00 63_cvs20070615
Howard Webb
webb.howard at gmail.com
Mon Jun 18 21:57:16 EDT 2007
I just downloaded and installed the latest. Definitely some improvements.
For the most part, so far, it all seems to be working well. Thank for all
the work.
I am trying to import some DEM files that appear to be in e00 raster format
(via http://www.msdis.missouri.edu/data/dem/index.htm#).
It looks like I should be able to import this via m.in.e00, but the module
seems to be missing (not in the bin directory). Is this a bug issue with
this module (hence left out of this build), the module is missing, or has
there been a replacement for this functionality?
Thanks,
Howard
View this message in context: http://www.nabble.com/m.in.e00-63_cvs20070615-tf3943855.html#a11187329
Sent from the Grass - Win mailing list archive at Nabble.com.
More information about the grass-windows
