[winGRASS] Re: Installing RasterTools extension with GEM
Enrico R. Crema enryu_crema at yahoo.it
Wed Mar 14 13:27:48 EDT 2007
Hi
I solved the problem by re-installing the PROJ.4 changing the destination directory. But i still have probelm installing other extensions, namely the General Statitics addon. The error message is the following:
Following modules are missing the 'description.html' file in src code:
ERROR: Compilation failed for these module(s):
/tmp/grass.extension.WyiAGo/GeneralStatistics/src/lib/ggsl
/tmp/grass.extension.WyiAGo/GeneralStatistics/src/lib/gstats
/tmp/grass.extension.WyiAGo/GeneralStatistics/src/vector/v.report
Run 'make' manually in each module's directory for details.
make: *** [default] Error 1
ERROR: source code could not be compiled.
                        Run again with option -v to see what is causing trouble.
Removing temporary extension files...DONE.
Removing temporary registration files...DONE.
Program exited with an error (code -4). Operation aborted.
Hope you can help me.
Thanks
Enrico
 L'email della prossima generazione? Puoi averla con la  nuova Yahoo! Mail
URL: http://lists.osgeo.org/pipermail/grass-windows/attachments/20070314/c1a47421/attachment.html
More information about the grass-windows mailing list
