[winGRASS] V.digit issues with TCL
Sampson, David
dsampson at NRCan.gc.ca
Fri Nov 9 09:14:22 EST 2007
Hey Folks,
Trying some new functions with the GRASS win binary.
I can use the GUI no problem, but todays issue is with v.digit.
I have one vector file of a road network loaded. I wanted to do some
edits to find nodes and such manualy as v.to.points for nodes and
vertices returned nothing.
I got a message saying the v.digit could not find init.tcl
My TCL is in C:\Tcl\lib\tcl8.4
And the file exists, but the directory is never checked....
Instead it tries to look in my apache2triad directory and a bunch of
GRASS directories.
I tried putting ina shortcut from the apache2triad directory to connect
(sorta line a symbolic link in linux) but no glory. I also created a TCL
env variable and added it to the path, still nothing.
The message ends "This probably means that TCL wasn't installed
properly"
I believe I followed the extra install steps....
The following is my batch file
@echo off
rem
rem #
rem # GRASS Initialization
rem #
rem
rem *******Environment variables***********
rem Uncomment and set the following values if they differ from the
indicated default
rem Directory where your .grassrc6 file will be stored
rem set HOME=%USERPROFILE%
rem Name of the wish (Tk) executable
rem set GRASS_WISH=wish.exe
rem Path to the shell command
set GRASS_SH=c:\msys\1.0\bin\sh.exe
rem Path to your web browser
rem set GRASS_HTML_BROWSER=%SYSTEMDRIVE%\PROGRA~1\INTERN~1\IEXPLORE.EX
set GRASS_HTML_BROWSER=C:\Program Files\Mozilla Firefox\firefox.exe
rem Path to the proj files (notably the epsg projection list)
rem set GRASS_PROJSHARE=\c\grass\share\proj
set GRASS_PROJSHARE=C:\GRASS\grass\share\proj
set WINGISBASE=c:\GRASS\grass\grass-6.3.cvs
"%WINGISBASE%\etc\init.bat" %*
All the regualr windows can find TCL just fine... am I missing something
else?...
Is this a script thing, a python thing, an environemnt variable thing
URL: http://lists.osgeo.org/pipermail/grass-windows/attachments/20071109/782e7701/attachment.html
More information about the grass-windows
