[winGRASS] V.digit issues with TCL
Fri Nov 9 11:06:06 EST 2007
Sampson, David wrote:
> Trying some new functions with the GRASS win binary.
> I can use the GUI no problem, but todays issue is with v.digit.
> I have one vector file of a road network loaded.  I wanted to do some
> edits to find nodes and such manualy as v.to.points for nodes and
> vertices returned nothing.
> I got a message saying the v.digit could not find init.tcl
> My TCL is in C:\Tcl\lib\tcl8.4
> And the file exists, but the directory is never checked....
> Instead it tries to look in my apache2triad directory and a bunch of
> GRASS directories.
Try setting the TCL_LIBRARY environment variable to C:\Tcl\lib\tcl8.4.
You may need to set TK_LIBRARY similarly.
IIRC, Windows versions of Tcl/Tk look for the library directory
relative to the location of the executable, which doesn't work if
you're using a custom program which uses the Tcl/Tk libraries rather
than the standard tclsh/wish programs.
Unix versions hard-code the default directory into the libraries, so
this problem doesn't arise.
More information about the grass-windows mailing list
