[winGRASS] v.db.addcol
Glynn Clements
glynn at gclements.plus.com
Sat Nov 10 04:06:09 EST 2007
Moritz Lennert wrote:
> > I have narrowed down the issue a bit: the problem only occurs with the
> > dbf driver, not with postgresql or sqlite. Up to now I have seen that
> > inserts and updates do not work.
> > Will look further.
> Found it:
> The rename function used to move the temporary dbf file to the correct
> filename of the table does not work correctly in windows, as it does not
> allow to rename to an existing file:
> "The rename function renames the file or directory specified by oldname
> to the name given by newname. The old name must be the path of an
> existing file or directory. The new name must not be the name of an
> existing file or directory"
> (http://msdn2.microsoft.com/en-us/library/zw5t957f(VS.71).aspx)
> So we'll need to find another function to use here.
> Glynn, any hints ?
Call remove() first.
More information about the grass-windows
