[GRASS-user] Re: [winGRASS] native winGRASS pre-alpha testers
needed
benjamin.ducke at ufg.uni-kiel.de
Wed Sep 5 05:36:28 EDT 2007
In addition, GRASS shell scripts and modules should be checked
and hardened for cases where spaces may appear in file or directory names.
On a unix system, users generally don't store stuff in paths with
spaces, but Windows by its very design encourages this.
E.g. the user's home folder may well be something like
C:\Windows\Documents and Settings\Default User\
This can easily break scripts and modules that need to interact
directly with the filesystem, e.g. for reading and writing ASCII
files.
If the user installs the WinGRASS binaries into a path with spaces,
also something Windows encourages, there might be further sources of
trouble.
So I'd recommend to do just that: install WinGRASS into a dir with
spaces, create a GRASS mapset, also in a path with spaces, and
work from there to find all the vulnerable bits and pieces.
Benjamin
> On 04/09/07 14:21, Ted Nebitko wrote:
>> Is there an index of those modules that are working and those that
>> require further testing?
> There is no such systematic index. What we know not to work at this stage:
> - some modules dealing with attributes of vector data (confirmed for
> v.out.ogr, but others are affected): these work intermittently, but
> often cause deadlocks. We are currently busy trying to hunt down this bug.
> - all d.* commands from the command line: there are no x-monitors in
> windows so none of these commands will work. All display has to happen
> within the GIS Manager gui.
> - d.vect.thematic: this is a script which cannot easily be ported to
> windows as it uses d.mon commands.
> - There might be other scripts that don't work.
> The rest potentially works, but still needs extensive testing since
> whether a module works or not might depend on the parameters used.
> Moritz
> grassuser mailing list
> grassuser at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
More information about the grass-windows
