R: R: [GRASS-windows] WinGRASS and MSYS Hanging - Need help for student
Marco Pasetti marco.pasetti at alice.it
Fri Apr 4 16:55:25 EDT 2008
>He is opening GRASS from MSYS using the MSYS shortcut in the GRASS program
group in the start menu. On my system, this opens a black window with a
command prompt.
>The problem the student is having is that the command prompt is not showing
up. I am not referring to the GRASS command prompt, but the MSYS command
prompt.
It's very stange!
Does he installed grass in a directory without spaces?
>All that appears is a cursor. For the output window, he is using the Run
button.
Grass crashes with every command?
Does run(gui) work?
MP
Da: Ryan Rosario [mailto:uclamathguy at gmail.com]
Inviato: venerdì 4 aprile 2008 22.47
A: Marco Pasetti
Cc: grass-windows at lists.osgeo.org
Oggetto: Re: R: [GRASS-windows] WinGRASS and MSYS Hanging - Need help for
student
command prompt.
prompt. All that appears is a cursor. For the output window, he is using the
Run button.
Ryan
On Fri, Apr 4, 2008 at 11:53 AM, Marco Pasetti <marco.pasetti at alice.it>
wrote:
	Hi Ryan,
	>When he opens MSYS to run GRASS, nothing shows up in the window
except the
	cursor. (There is no command prompt)
	Because he didn't start GRASS from MSYS. Please, read the "launching
GRASS"
	section in README file; you can find it in grass directory or here:
	http://grass.osgeo.org/grass63/binary/mswindows/#Launching%20GRASS
	>I asked him to instead use the Output window in the GUI and start
	using the GRASS shortcut. However, when he enters a command and hits
Run,
	GRASS hangs and then Windows brings up the "GRASS has encountered an
error
	and must close."
	Did he used Run or Run GUI?
	Could you give me the command that created such error?
	Marco
	Da: grass-windows-bounces at lists.osgeo.org
	[mailto:grass-windows-bounces at lists.osgeo.org] Per conto di Ryan
Rosario
	Inviato: venerdì 4 aprile 2008 18.42
	A: grass-windows at lists.osgeo.org
	Oggetto: [GRASS-windows] WinGRASS and MSYS Hanging - Need help for
student
	I am TAing a brand new class that is using GRASS. I have a student
that is
	using WinGRASS 6.3RC6. He is running Windows XP.
except the
Run,
error
	and must close."
	Has anyone experienced this or have any ideas on how I can help him
resolve
	this?
	Thanks,
	Ryan
<a href="http://www.spreadfirefox.com/?q=affiliates&amp;id=0&amp;t=180"><img
border="0" alt="Get Thunderbird!" title="Get Thunderbird!"
src="http://sfx-images.mozilla.org/affiliates/thunderbird/thunderbird_large.
png"/></a>
More information about the grass-windows mailing list
