R: [GRASS-windows] WinGRASS and MSYS Hanging - Need help for
student
Ryan Rosario
uclamathguy at gmail.com
Fri Apr 4 16:47:17 EDT 2008
He is opening GRASS from MSYS using the MSYS shortcut in the GRASS program
group in the start menu. On my system, this opens a black window with a
command prompt.
The problem the student is having is that the command prompt is not showing
up. I am not referring to the GRASS command prompt, but the MSYS command
prompt. All that appears is a cursor. For the output window, he is using the
Run button.
Ryan
On Fri, Apr 4, 2008 at 11:53 AM, Marco Pasetti <marco.pasetti at alice.it>
wrote:
> Hi Ryan,
> >When he opens MSYS to run GRASS, nothing shows up in the window except
> the
> cursor. (There is no command prompt)
> Because he didn't start GRASS from MSYS. Please, read the "launching
> GRASS"
> section in README file; you can find it in grass directory or here:
> http://grass.osgeo.org/grass63/binary/mswindows/#Launching%20GRASS
> >I asked him to instead use the Output window in the GUI and start GRASS
> using the GRASS shortcut. However, when he enters a command and hits Run,
> GRASS hangs and then Windows brings up the "GRASS has encountered an error
> and must close."
> Did he used Run or Run GUI?
> Could you give me the command that created such error?
> Marco
> ________________________________
> Da: grass-windows-bounces at lists.osgeo.org
> [mailto:grass-windows-bounces at lists.osgeo.org] Per conto di Ryan Rosario
> Inviato: venerdì 4 aprile 2008 18.42
> A: grass-windows at lists.osgeo.org
> Oggetto: [GRASS-windows] WinGRASS and MSYS Hanging - Need help for student
> Hi,
> I am TAing a brand new class that is using GRASS. I have a student that is
> using WinGRASS 6.3RC6. He is running Windows XP.
> When he opens MSYS to run GRASS, nothing shows up in the window except the
> and must close."
> Has anyone experienced this or have any ideas on how I can help him
> resolve
> this?
> Thanks,
> Ryan
<a href="http://www.spreadfirefox.com/?q=affiliates&id=0&t=180"><img
border="0" alt="Get Thunderbird!" title="Get Thunderbird!" src="
http://sfx-images.mozilla.org/affiliates/thunderbird/thunderbird_large.png"/></a>
URL: http://lists.osgeo.org/pipermail/grass-windows/attachments/20080404/60844e12/attachment.html
More information about the grass-windows
