[GRASS-windows] msys grass63 and wingrass
Glynn Clements
glynn at gclements.plus.com
Sun Feb 10 13:13:03 EST 2008
Gerald Nelson wrote:
> Re the "#!" notation, my 'solution' was just to delete that line. Maybe not
> elegant but it did work for me.
> So is the idea to have wingrass either automatically launch a command line
> window along with the gui or have an option somewhere in the gui to open the
> window, or ...
No idea. The point is that you can use GRASS from a normal Windows
command prompt. You only need to have bash installed to run bash
scripts; you don't need to start an interactive bash shell.
More information about the grass-windows
