[GRASS-windows] NVIZ kills everything in wingrass 6.3 CVS
Glynn Clements
glynn at gclements.plus.com
Wed Feb 13 13:33:10 EST 2008
Sampson, David wrote:
> When I try to involke NVIZ with only a single 2d vector it kills the
> display. This means that as soon as I run NVIZ, nothing comes up but the
> display is not usebable. Nore is a new display useable. Exit and restart
> is the only solution.
This suggests a bug in the OpenGL driver for your graphics hardware.
The first step is to check whether the vendor has issued updated
drivers. Failing that, you might be able to use Mesa (a software
OpenGL implementation), but I'm not sure of the details.
More information about the grass-windows
