[GRASS-windows] NVIZ kills everything in wingrass 6.3 CVS
Sampson, David
dsampson at NRCan.gc.ca
Wed Feb 13 16:14:29 EST 2008
When I run NVIZ in the demo mode, it works until I try loading a file
-----Original Message-----
[mailto:grass-windows-bounces at lists.osgeo.org] On Behalf Of Glynn
Clements
Sent: Wednesday, February 13, 2008 13:33
To: Sampson, David
Cc: grass-windows at lists.osgeo.org
Subject: Re: [GRASS-windows] NVIZ kills everything in wingrass 6.3 CVS
Sampson, David wrote:
> When I try to involke NVIZ with only a single 2d vector it kills the
> display. This means that as soon as I run NVIZ, nothing comes up but
> the display is not usebable. Nore is a new display useable. Exit and
> restart is the only solution.
This suggests a bug in the OpenGL driver for your graphics hardware.
The first step is to check whether the vendor has issued updated
drivers. Failing that, you might be able to use Mesa (a software OpenGL
implementation), but I'm not sure of the details.
grass-windows mailing list
http://lists.osgeo.org/mailman/listinfo/grass-windows
More information about the grass-windows
