[GRASS-windows] bash: startx: command not found, X11?
ojanen
mg650c at gmail.com
Thu Feb 21 10:51:39 EST 2008
How much of X? That's a good question. I install GRASS using these
instructions and it grabs whatever files that are needed (or it always has
in the past): http://grass.ibiblio.org/grass62/binary/mswindows/
I do see an X11R6 directory in /usr, and /usr/X11R6/bin is in my path as
well as in /etc/profile
I guess I'll reinstall, per your advice on which packages and xterm. Wish me
luck, and thanks. :)
Glynn Clements wrote:
> How much of X have you installed?
> FWIW, "startx" is in the X-startup-scripts package. So far as X is
> concerned, you'll also need most of the xorg-x11-* packages (you can
> omit some of the font packages) and the xterm package.
> Also, /usr/X11R6/bin needs to be in the path; add it in /etc/profile
> if it isn't there already.
> Glynn Clements <glynn at gclements.plus.com>
> grass-windows mailing list
> grass-windows at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-windows
View this message in context: http://www.nabble.com/bash%3A-startx%3A-command-not-found%2C---X11--tp15596164p15613504.html
Sent from the Grass - Win mailing list archive at Nabble.com.
More information about the grass-windows
