[GRASS-windows] bash: startx: command not found, X11?
Glynn Clements
glynn at gclements.plus.com
Thu Feb 21 21:17:45 EST 2008
ojanen wrote:
> How much of X? That's a good question. I install GRASS using these
> instructions and it grabs whatever files that are needed (or it always has
> in the past): http://grass.ibiblio.org/grass62/binary/mswindows/
Odd. The setup.ini file there lists xorg-x11-base as a a requirement,
and xorg-x11-base has most of the other X11 packages as a requirement,
including X-startup-scripts. At least, it does in the version I have
here; admittedly, that's rather out of date.
More information about the grass-windows
