[GRASS-windows] launching bash script
Fabio D'Ovidio fabiodovidio at gmail.com
Tue Jan 22 07:52:23 EST 2008
Yes, the script is v.coordinate...so i have decided to use Georectify tool.
My problem now is that i have no much experience with GRASS GIS...
How can I set XY location to import my no-georef. data?
Moritz Lennert ha scritto:
> On 22/01/08 11:48, Fabio D'Ovidio wrote:
>> Hi!
>> I have installing wingrass on Windows XP following:
>> http://geog-pc40.ulb.ac.be/grass/wingrass/README
>> I have installed msys...and configured it in grass.bat
>> I have to work with v.coordinate script...how can I lauch it as a
>> bash script?
> I imagine the script attached to this mail:
> http://www.mail-archive.com/grass-italia@listserv.unipr.it/msg00440.html
> Before answering your question: my Italian is not good enough to
> really understand what this script does, but I having the feeling it
> reproduces what the "georectify" tool does when you decide to rectify
> a vector. So maybe you can just use that.
> Probably the easiest way to launch a bash script with native wingrass
> is to launch grass from within the msys shell:
> 1) Open msys shell
> 2) type /c/grass/bin/grass (not grass.bat ! - adapt path to your
> situation)
> 3) launch gis.m
> Or, if your grass.bat is correctly configured (path to sh.exe set and
> path to msys/bin and msys/lib set) you can do it from within a cmd.exe
> window:
> 1) Open cmd.exe
> 2) Launch grass in text mode: c:\grass\bin\grass.bat -text
> 3) Launch the script from the command line
> Or, if the script is in your PATH:
> 1) Launch grass in gui mode
> 2) type script name in console part of the Output window
> However, v.coordinate will not work in windows since it uses
> x-monitors. These are not supported in wingrass. So, I guess you
> really should try with the georectify tool (in the File menu).
> Moritz
Ing. Fabio D'Ovidio
iQuadro - Informatica e Innovazione s.r.l.
Via C. Pisacane 23, Aversa (CE) - 81031
Web : www.ii2.it
Tel.: 081 197 57 600
mail: fabiodovidio at gmail.com
More information about the grass-windows mailing list
