[GRASS-windows] Large file support?
Glynn Clements
glynn at gclements.plus.com
Tue Jul 29 09:19:37 EDT 2008
Jonathan Greenberg wrote:
> Enabling the lfs flag I don't think is
> the issue -- I think *grass* can deal with big files, but the GDAL
> compile it is relying on probably isn't configured correctly.
You should be able to confirm or refute this by running gdal_translate
on such a file.
Also, if the GDAL header files are installed, you can see whether LFS
was configured from the defines at the bottom of cpl_config.h.
More information about the grass-windows
