[GRASS-windows] Large file support?
    Frank Warmerdam
    warmerdam at pobox.com
    Tue Jul 29 13:07:40 EDT 2008
Marco Pasetti wrote:
> Hi Jonathan,
>> I remember having problems with LFS and GDAL when we were compiling
>> starspan for windows use (starspan.casil.ucdavis.edu) -- I'll ask our
>> lead programmer about that.  We used to have to use:
>>    export CPPFLAGS=-D_FILE_OFFSET_BITS=64
>>    export CXXFLAGS=-D_FILE_OFFSET_BITS=64
>>    export CFLAGS=-D_FILE_OFFSET_BITS=64
>> to get GDAL to compile with LFS correctly, although we haven't used
>> that for a long time.
> yes, after reading some things more, I suppose that this is the problem
> I suppose that we could fix it adding to the GDAL configure the option:
> --with-unix-stdio-64=yes
> but I cannot test it right now... I added it to my to-do list
Marco,
Particular configuration options may be necessary to get large file support
on a given system.  I presume you are building with the unsupported MingW
configuration for win32?  The --with-unix-stdio-64 option would be one
to try out, or the suggested file offset macros described above.
BTW, to create a large file with GDAL you should be able to do something
like:
   gdal_translate utm.tif -outsize 70000 70000 big.tif
Of course if large file access isn't working this is likely to fail, but
then that's a clue.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
More information about the grass-windows
