[GRASS-windows] switching to GRASS, 6.2.3 or GRASS 6.3.0?
Michael Denslow michael.denslow at gmail.com
Tue Oct 7 09:42:01 EDT 2008
Hi Marco,
On Tue, Oct 7, 2008 at 2:55 AM, Marco Pasetti <marcopstt at gmail.com> wrote:
> Hi Michael,
>> 1. Below are the contents of the file. now that I have found it should
>> I delete it?
> No. Move it to C:\GRASS\msys\home\"YOURUSERNAME"
> The content of the file is OK. The problem may rely into the .grassrc6 file,
> I suppose.
>> 2. my account contains spaces in the path name C:\Documents and
>> Settings\"MYNAME"
> OK. But your username is "Michael" or "Michael Denslow"? (I suppose the
> latter, because of the strange warning you detected)
the path name is actually:
C:/Documents and Settings/Katz&Denslow
I think this is what you mean by username.
> This is what your .grassrc6 file should contain, just after the installation
> of GRASS:
Where is this file located? Didn't I delete it previously?
Also the GIS DataBase folder is located in the following path
C:\Documents and Settings\Katz&Denslow\My Documents\GIS DataBase
> GISDBASE: C:/Documents and Settings/Michael Denslow/Documents/GIS DataBase
> LOCATION_NAME: demolocation
> MAPSET: PERMANENT
> GRASS_GUI: tcltk
> Regards,
> Marco
Is this a lost cause should I try to install GRASS 6.2.3?
Michael
More information about the grass-windows mailing list
