[GRASS-windows] r.report, r.patch
Michael D. michael.denslow at gmail.com
Fri Oct 24 12:41:24 EDT 2008
Hello GRASS users, I seem to be having the same problem with r.report as
mentioned below. I am using Windows XP.
Helena Mitasova wrote:
> 1. r.report does not work for two students (one has VISTA one has XP)
> it does not print anything - it works for me
> and others - has anybody had a similar problem?
I get the following error when I type the command
r.report -h towns units=h
into the command line (this is an example from page 101 of the Neteler and
Mitasova book)
Sorry <and> is not a valid option
Sorry <Setting/md/My> is not a valid option
and so on...
I think it has to do with spaces in the file paths. So can I just move the
GIS Database folder to a path without spaces and remove the space in the
folder name? I am not sure what to do here. Also I am not a programmer so I
am in need of a simple suggestion.
Thanks in advance,
Michael
View this message in context: http://www.nabble.com/-GRASS-windows--r.report%2C-r.patch-tp19742366p20153585.html
Sent from the Grass - Win mailing list archive at Nabble.com.
More information about the grass-windows mailing list
