[GRASS-windows] r.report, r.patch
Markus Neteler
neteler at osgeo.org
Fri Oct 24 14:13:17 EDT 2008
On Fri, Oct 24, 2008 at 6:41 PM, Michael D. <michael.denslow at gmail.com> wrote:
> Hello GRASS users, I seem to be having the same problem with r.report as
> mentioned below. I am using Windows XP.
> Helena Mitasova wrote:
>> 1. r.report does not work for two students (one has VISTA one has XP)
>> it does not print anything - it works for me
>> and others - has anybody had a similar problem?
> I get the following error when I type the command
> r.report -h towns units=h
> into the command line (this is an example from page 101 of the Neteler and
> Mitasova book)
> Sorry <and> is not a valid option
> Sorry <Setting/md/My> is not a valid option
> and so on...
> I think it has to do with spaces in the file paths. So can I just move the
> GIS Database folder to a path without spaces and remove the space in the
> folder name? I am not sure what to do here. Also I am not a programmer so I
> am in need of a simple suggestion.
Yes, it should be as simple as that (no white spaces in the path).
Please continue to report so that we can try to fix them.
Markus
More information about the grass-windows
