[GRASS-windows] r.report, r.patch
Glynn Clements
glynn at gclements.plus.com
Tue Oct 28 12:45:50 EDT 2008
Markus Neteler wrote:
> >>> I get the following error when I type the command
> >>> r.report -h towns units=h
> >>> into the command line (this is an example from page 101 of the Neteler and
> >>> Mitasova book)
> >>> Sorry <and> is not a valid option
> >>> Sorry <Setting/md/My> is not a valid option
> >>> and so on...
> >> Yes, it should be as simple as that (no white spaces in the path).
> >> Please continue to report so that we can try to fix them.
> > Thanks for the suggestion, this fixed the problem. Both functions work
> > as expected now. Should I report this in a more formal way?
> I recently fixed a series of vector commands for white space
> problems (which I could reproduce on Linux) but I don't
> manage to reproduce the r.report problem.
As I mentioned before, the whitespace problem with r.report was fixed
in 7.0 with r33627. You back-ported this fix to 6.4 with r33629, so
you won't be able to reproduce it with a current version.
More information about the grass-windows
