[GRASS-windows] r.sim.water
Helena Mitasova
hmitaso at unity.ncsu.edu
Fri Sep 12 12:19:09 EDT 2008
Markus,
thanks for testing - I think simwe has a problem on MSwindows due to
the problem with sites to vector update - that is why Glynn has disabled
it. I need to comment out the site related stuff and it should run
(I have the comments from Glynn, I just did not have time to get to it).
I need to get it running on windows for my class, so I am going to get
to it right away.
Stefan - you can try r.hydro.casc2d, it was recently updated and it is
in add-ons, it may soon get back into the main GRASS so it would be nice
if somebody could run it,
Helena
On Fri, 2008-09-12 at 12:00 -0400, grass-windows-request at lists.osgeo.org
wrote:
> Send grass-windows mailing list submissions to
> grass-windows at lists.osgeo.org
> To subscribe or unsubscribe via the World Wide Web, visit
> http://lists.osgeo.org/mailman/listinfo/grass-windows
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
> grass-windows-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of grass-windows digest..."
> Today's Topics:
> 1. Re: r.sim.water (Stefan Frerichs)
> 2. Re: r.sim.water (Markus Neteler)
> Message: 1
> Date: Fri, 12 Sep 2008 10:59:33 +0200
> From: Stefan Frerichs <frerichs at bkr-ac.de>
> Subject: Re: [GRASS-windows] r.sim.water
> To: grass-windows at lists.osgeo.org
> Message-ID: <48CA2F75.4070303 at bkr-ac.de>
> Content-Type: text/plain; charset=ISO-8859-1
> Hi Markus,
> I have imported a elevation IMG to Grass and get the following DEM:
> | Layer: dgm at mapset Date: Wed Sep 10 11:35:01 2008 |
> | Mapset: Mapset Login of Creator: stefan |
> | Location: Location |
> | DataBase: Path/DLM-D |
> | Title: ( dgm ) |
> | Timestamp: none |
> | Type of Map: raster Number of Categories: 255 |
> | Data Type: FCELL |
> | Rows: 964 |
> | Columns: 1202 |
> | Total Cells: 1158728 |
> | Projection: Transverse Mercator |
> | N: 5652051.21010544 S: 5627951.21010544 Res: 25 |
> | E: 2540019.37538876 W: 2509969.37538876 Res: 25 |
> | Range of data: min = -263.843994 max = 299.535004 |
> | Data Description: |
> | generated by r.in.gdal |
> | Comments: |
> | r.in.gdal -o input="Path\dgm.img" output="dgm" |
> >From here I set the region-settings to the DEM (as seen in my post to
> your further inquiry) and build up dgm_dx and dgm_dy with r.slope.aspect:
> r.slope.aspect elevation=dgm at mapset format=degrees prec=float dx=dgm_dx
> dy=dgm_dy zfactor=1.0 min_slp_allowed=0.0
> Into the region I build a fractal map as model for a heavy rainfall (as
> described in my first inquires) with this result:
> | Layer: rainfall_d50 at mapset Date: Thu Sep 11 10:10:37 2008 |
> | Mapset: mapset Login of Creator: stefan |
> | Location: location |
> | Title: ( rainfall_d50 ) |
> | Timestamp: none |
> | Data Type: DCELL |
> | Rows: 964 |
> | Columns: 1202 |
> | Range of data: min = 2.787233 max = 83.784941 |
> | Data Description: |
> | generated by r.mapcalc |
> | Comments: |
> | surf_fractal_max300 at mapset / 179.030000 * 50 |
> With this input I try to calculate the overland flow with r.sim.water
> r.sim.water -t elevin=dgm at mapset dxin=dgm_dx at mapset dyin=dgm_dy at mapset
> rain=rainfall_d50 at mapset rain_val=50 infil_val=0.0 manin_val=0.1
> depth=rainfall_depth disch=rainfall_dish nwalk=0 niter=10 outiter=5
> density=200 diffc=0.8 hmax=0.3 halpha=4.0 hbeta=0.5
> with the well-known result ("Fr diesen Befehl ist nicht gengend
> Speicher verfgbar") and r.sim.water-crash.
> As a variant I doesn't use the fractalmap rainfall_d50 at mapset, but then
> r.sim.water crashes without a message.
> When you (Markus) like to repeat my tries I can send you a link to a
> ftp-server where you can download my data at all are a specific map
> alone (only to Markus at this point, sorry to the list). My only
> assumption, why r.sim.water not functioned with my data is, that the
> rasters are too large ...
> Thank you very much for the time, you spend so long with my problem
> Stefan
> Markus Neteler schrieb:
> > Hi Stefan,
> > On Thu, Sep 11, 2008 at 11:01 AM, Stefan Frerichs <frerichs at bkr-ac.de> wrote:
> >> Hi Markus,
> >> g.region -p have following output:
> >> rojection: 99 (Transverse Mercator)
> > ouch!
> >> zone: 0
> >> datum: potsdam
> >> ellipsoid: bessel
> >> north: 5652051.21010544
> >> south: 5627951.21010544
> >> west: 2509969.37538876
> >> east: 2540019.37538876
> >> nsres: 25
> >> ewres: 25
> >> rows: 964
> >> cols: 1202
> >> cells: 1158728
> >> ("rojection" sic!)
> > (That's very strange, cannot trace any broken word like this in 6.3.)
> >> The Map-Unit is meter, as the elevation-raster comes in Gau-Krger
> > ok. While I have a GK location, could you send the instructions to
> > repeat your example? Or package up the location with relevant
> > maps only for a test?
> > Markus
> _____________________________________________________
> BKR Aachen Kirberichshofer Weg 6
> Castro & Hinzen D-52066 Aachen
> Stadtplaner, Umweltplaner Fon +49 241 47058-0
> Fax +49 241 47058-15
> Amtsgericht Essen PR 43 www.bkr-ac.de
> Message: 2
> Date: Fri, 12 Sep 2008 16:59:52 +0200
> From: "Markus Neteler" <neteler at osgeo.org>
> To: "Stefan Frerichs" <frerichs at bkr-ac.de>
> Cc: grass-windows at lists.osgeo.org
> Message-ID:
> <86782b610809120759q727b5c51i58f05709a561c554 at mail.gmail.com>
> Hi Stefan,
> I have downloaded your location from the secret server and run
> r.sim.water -t elevin=dgm dxin=dgm_dx dyin=dgm_dy \
> rain=surf_fractal_d50 rain_val=50 infil_val=0.0 manin_val=0.1 \
> depth=dgm_depth disch=dgm_disch niter=10 outiter=5 diffc=0.8 \
> default nwalk=2317456, rwalk=2317456.000000
> Min elevation = -263.84 m
> Max elevation = 299.54 m
> Mean Source Rate (rainf. excess or sediment) = 0.000013 m/s or kg/m2s
> Mean flow velocity = 1.530536 m/s
> Mean Mannings = 0.100375
> Number of iterations = 36 cells
> Time step = 4.08 s
> 11% ... 100%
> Resulting maps are created:
> dgm_depth.0294 dgm_depth.0588
> dgm_disch.0294 dgm_disch.0588
> During execution (Linux, GRASS 6.4.svn), I have low memory consumption:
> Mem: 3096356k total, 1878772k used, 1217584k free, 190628k buffers
> r.sim.water uses 6.6% of the memory, so not really much.
> I don't see relevant changes in r.sim.water between 6.3.svn and 6.4.svn.
> Possibly there is a Windows related memory issue?
> Please submit a bug report:
> http://grass.osgeo.org/grass63/binary/mswindows/native/#How%20to%20Submit%20Bugs
> I am not sure how to debug under Windows (here MingW). Maybe someone
> here could give you hints
> In near future, we'll prepare a 6.4.0 release branch, hopefully a new Windows
> version will be prepared then.
> Sorry for being no more help right now, under Linux it works.
> Markus
> On Fri, Sep 12, 2008 at 10:59 AM, Stefan Frerichs <frerichs at bkr-ac.de> wrote:
> > Hi Markus,
> > | Title: ( dgm ) |
> > | Timestamp: none |
> > | Data Type: FCELL |
> > | Rows: 964 |
> > | Columns: 1202 |
> > | Data Description: |
> > | Comments: |
> > | Timestamp: none |
> > | Data Type: DCELL |
> > | Rows: 964 |
> > | Columns: 1202 |
> > | Data Description: |
> > | Comments: |
> > Stefan
> >> Hi Stefan,
> >>> Hi Markus,
> >> ouch!
> >>> zone: 0
> >>> datum: potsdam
> >>> ellipsoid: bessel
> >>> nsres: 25
> >>> ewres: 25
> >>> rows: 964
> >>> cols: 1202
> >>> cells: 1158728
> >>> ("rojection" sic!)
> >> Markus
More information about the grass-windows
