[GRASS-windows] Re: r.sim.water
Helena Mitasova hmitaso at unity.ncsu.edu
Fri Sep 12 12:59:40 EDT 2008
On Fri, 2008-09-12 at 18:52 +0200, Markus Neteler wrote:
> Helena,
> On Fri, Sep 12, 2008 at 6:19 PM, Helena Mitasova <hmitaso at unity.ncsu.edu> wrote:
> > Markus,
> > thanks for testing - I think simwe has a problem on MSwindows due to
> > the problem with sites to vector update - that is why Glynn has disabled
> > it.
> when was it disabled (don't remember)? Post-6.3.?
in trunk, I think it may still be in GRASS6.4 - I will check.
I just ran it and I can confirm that it crashes on MS windows -
we are running Marco's GRASS63 binary. In runs on GRASS63 linux version
(compiled from source) and on older GRASS63 on Mac.
Helena
> > I need to comment out the site related stuff and it should run
> > (I have the comments from Glynn, I just did not have time to get to it).
> > I need to get it running on windows for my class, so I am going to get
> > to it right away.
> > Stefan - you can try r.hydro.casc2d, it was recently updated and it is
> > in add-ons, it may soon get back into the main GRASS so it would be nice
> > if somebody could run it,
> the trick is that it needs to be compiled on Windows with MingW...
> Markus
More information about the grass-windows mailing list
