[GRASS-windows] WinGRASS: Test Build on Vista
Marco Pasetti
marcopstt at gmail.com
Mon Sep 15 05:08:30 EDT 2008
Hi Peter,
> Marco
> I am new to GRASS and have successfully installed 6.3.0-4 on PCs running
> Windows 2000 and XP. However the same version installed on a Vista PC
> fails to run with the following messages
> g.dirseps is not recognised as an internal or external command, operable
> program or batchfile
> g.gisenv is not recognised as an internal or external command, operable
> "c:\GRASS\etc\clean_temp" is not recognised as an internal or external
> command, operable program or batchfile
> and these errors in the startup script
> GISBASE (read trace on "env(env)") invoked from within
> "source $env(GISBASE)/etc/gtcltk/gsmg.tcl"
> (file "c:\GRASS\etc\gis.set.tcl" line 29)
> "lappend auto_path $env(GISBASE)/bwidget"
> (file "c:\GRASS\etc\gm\gm.tcl" line 22)
> Regards
> Peter Lawrence
> Perth
> Western Australia
I woud need more info about that, but it seems that something failed in
writing the grass63.bat file.
Could you post the content of that file, please?
Try to delete the .grassrc6 file in your user root (I suppose
C:\Users\Peter), the try to restart GRASS.
Regards,
Marco
More information about the grass-windows
