[GRASS-windows] Grass an R statistic program failure
Milton Cezar Ribeiro
miltinho.astronauta at gmail.com
Wed Sep 24 09:08:02 EDT 2008
Hi Martin,
How about you install the recent version of R (2.7.2, I believe).
Another thing is that you need to call R from your grass63 prompt. So you
need to start your grass63 using MSYS shortcut instead of GUI/grass).
I hope this helps,
miltinho
brazil
2008/9/24 Martin Maier <martmai at gmx.de>
> Hey,
> I am trying to get the R statistic program (2.4.0) work within grass (6.3.0
> native windows installer) on a W2K machine, but it fails.
> It is possible to start R from within the GRASS command line (spearfish
> demolocation) and I am able to load the 'spgrass6' library (no errors while
> loading the library). But when I am trying do execute 'gmeta6()' it fails.
> Error: g.region not found. Same with 'readRAST6', error: g.proj not found.
> Any ideas?
> Martin
> grass-windows mailing list
> grass-windows at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-windows
URL: http://lists.osgeo.org/pipermail/grass-windows/attachments/20080924/50ecea3b/attachment.html
More information about the grass-windows
