[GRASS-windows] v.in.ogr
Zahid Parvez
grassgisbangladesh at gmail.com
Sun Sep 28 11:28:37 EDT 2008
Dear Grass users
Software: windows *native Grass 63* and *spearfish 60* data
Problem: facing problem in "*v.in.ogr*" command.
Description:
>>> Successfully started GRASS GIS and spearfish data loaded.
>>> First opened File -> Import -> Vector map -> Multiple formats using OGR.
>>> v.in.ogr window appears
>>> First Parameter needed is "path to the shape file (OGR data source
name)"
Suppose my shape file data is in location "C:\world_factbk"
So I have given the path C:\world_factbk in OGR Datasource name box.
>>> name of the vector map to be created (Name of output vector map): worlds
>>> name of the file shp to be imported (OGR layer name), without
extension:
world_factbk
>>> Override projection is check box is clicked.
>>> RUN is clicked
Output in GIS.m window:
ERROR: Unable to open data source <C:/world_factbk/world_factbk>
I wander what will be its solution
Sincerely yours
Md.Zahid Parvez
URL: http://lists.osgeo.org/pipermail/grass-windows/attachments/20080928/9b730d64/attachment.html
More information about the grass-windows
