[GRASS-windows] GRASS add-ons for Windows users
Olivier Vannier olivier.vannier at hmg.inpg.fr
Mon Apr 19 05:05:28 EDT 2010
Hi all,
Thanks Markus and Antonio for your answers.
I finally succeeded in installing the r.stream.basins addon I needed.
 I followed, step-by-step, the advices on how to install and configure
MinGW in order to compile Grass-6.4 on my windows system (described here
: http://trac.osgeo.org/grass/wiki/CompileOnWindows). Then the problem I
had is that some libraries needed by the addon where missing in my
own-compiled Grass 6.4 /lib/ folder. The solution I found was to copy
and paste theses libraries (libgrass_gis, libgrass_vect, libgrass_dig2,
libgrass_dbmibase, libgrass_dbmiclient) from the /extralib/ folder of
another precompiled winGRASS 6.4 I had on my machine. Not so clean, but
it works, and that's the main thing !
Thanks again to all the development team.
Olivier
Markus Neteler a écrit :
> On Tue, Apr 13, 2010 at 4:32 PM, Olivier Vannier
> <olivier.vannier at hmg.inpg.fr> wrote:
>> Hi all,
>> I'm quite new in using GRASS, and I need to install some GRASS add-ons
>> (r.stream.*). I'm afraid it will not be easy for the poor winGRASS user I am
>> ! I'm using GRASS 6.4 (installed with OSGeo4w), and I recently installed
>> GRASS 7.0 "standalone" (I even made some tests with GRASS 6.5). All this on
>> Windows XP Pro (32 bit).
>> Since my compilation attempts using MSys failed, I looked this discussion
>> archive. I read Antonio Rocha's previous messages, espacially the one on
>> compiling r.example with GRASS 6.4, but I didn't get the ending of the
>> discussion : Did you finally achieve your quest Antonio ? If yes I'm really
>> interested in following you in the compilation adventure !
> [did he post in this list? Perhaps he's not subscribed here]
>> If no, what is the solution for Windows users willing to use add-ons ? I
>> thought that the new module g.extension could help us, but :
>> - It is currently not yet operationnal on GRASS 7.0 ? (nothing occurs when
>> typing "g.extension" in the command line) ;
> It is not quite operational for Windows in 6.x. In GRASS 7, it has been
> rewritten in Python (I still vote for backport) with the hope that it is
> portable.
>> - It leads to the following error message on GRASS 6.5 :
>> g.extension extension=r.stream.basins
>> svnurl=https://svn.osgeo.org/grass/grass-addons/ prefix=C:/GRASS-65-SVN/
>> which: wget: unknown command
>> Fetching <r.stream.basins> from GRASS-Addons SVN (be patient)...
>> A r.stream.basins\main.c
>> A r.stream.basins\description.html
>> A r.stream.basins\global.h
>> A r.stream.basins\catchment.c
>> A r.stream.basins\io.c
>> A r.stream.basins\Makefile
>> R‚vision 41835 extraite.
>> mkdir -p /osgeo4w/usr/src/grass6_devel/bin.i686-pc-mingw32
>> Compiling r.stream.basins...
>> C:/GRASS-65-SVN/include/Make/Module.make:25: warning:
>> overriding commands for target `install'
>> C:/GRASS-65-SVN/include/Make/Rules.make:82: warning:
>> ignoring old commands for target `install'
>> mkdir -p /osgeo4w/usr/src/grass6_devel/dist.i686-pc-mingw32/include/grass
>> mkdir -p /osgeo4w/usr/src/grass6_devel/dist.i686-pc-mingw32/lib
>> mkdir -p /osgeo4w/usr/src/grass6_devel/dist.i686-pc-mingw32/bin
>> mkdir -p /osgeo4w/usr/src/grass6_devel/dist.i686-pc-mingw32/etc
>> mkdir -p /osgeo4w/usr/src/grass6_devel/dist.i686-pc-mingw32/driver
>> mkdir -p /osgeo4w/usr/src/grass6_devel/dist.i686-pc-mingw32/driver/db
>> mkdir -p /osgeo4w/usr/src/grass6_devel/dist.i686-pc-mingw32/fonts
>> test -d OBJ.i686-pc-mingw32 || mkdir -p OBJ.i686-pc-mingw32
>> gcc.exe: installation problem, cannot exec `cc1': No such
>> file or directory
> Using my preferred search engine, I found quite some results.
> Perhaps you can take a look, it looks like a (local) MinGW problem
> to be solved before trying to compile Addons.
>> Is the problem fixable ? Or should I better forget about installing GRASS
>> add-ons on my Windows machine ?
> Please don't (yet) :-)
> Markus
More information about the grass-windows mailing list
