[GRASS-windows] Re: [GRASS-user] Cygwin and GRAS
Nikos Dumakis
nikosdu1980 at gmail.com
Wed Jan 13 04:33:18 EST 2010
Hello markus
FVWM is installed and a few others libraries... But none of those commands
work. It doesn't recognize the commands.
GRASS command-line version seems to be working. Not the GUI versions (of
course).
Anyone has a suggestion?
Thanks
Niko
On Tue, Jan 12, 2010 at 9:14 PM, Markus Neteler <neteler at osgeo.org> wrote:
> On Tue, Jan 12, 2010 at 5:50 PM, Nikos Dumakis <nikosdu1980 at gmail.com>
> wrote:
> > Greetings
> > I have just installed GRASS Cygwin installation
> > (http://grass.itc.it/grass64/binary/mswindows/cygwin/).
> > When I double-clicked at Cygwin logo and inserted startx at Command-line
> I
> > got this error
> > Bash: startx: command not found
> Did you install
> fvwm
> ? It should auto-select X11.
> The script's name could also be
> startxwin.sh
> > And when I inserted grass64 I got the same error:
> > Bash: grass64: command not found
> > What packages am I missing?
> GRASS :) Note that the "Part 2" of the installation has become
> a bit tricky due to changes in Cygwin.
> Markus
URL: http://lists.osgeo.org/pipermail/grass-windows/attachments/20100113/810af852/attachment.html
More information about the grass-windows
