[GRASS-windows] Error while adding scale and legend in GRASS6.4
António Rocha
antonio.rocha at deimos.com.pt
Tue Jan 19 07:02:58 EST 2010
I've sent a similar message to Grass-user but, I think this might be a
GRASS_windows error.
I'm using native WinGRASS 6.4
My region is defined as:
projection: 3 (Latitude-Longitude)
zone: 0
datum: wgs84
ellipsoid: wgs84
north: 83:00:10N
south: 34N
west: 11:00:10W
east: 41:00:00.000002E
nsres: 0:00:10
ewres: 0:00:10
rows: 17641
cols: 18721
cells: 330257161
As Hamish has explained me, I'm not able to add a scale bar due to the
fact that this is a Lat/Lon Projection.
Never the less I can add only north Arrow if I choose "add only north
arrow" in d.barscale>Optional.
But If I try to add Scale, I get a Error Window with:
*"Failure executing 'd.barscale.exe at=0,5 --q'
Details: Error: d.barscale.exe does not work with a latitude-longitude*
And the following is printed in command output:
*Traceback (most recent call last):
File "c:\OSGeo4W\apps\grass\grass-6.4.0svn\etc\wxpython\gu
i_modules\gdialogs.py", line 416, in OnOK
# close dialog
File "C:\GRASS6\etc\wxpython\gui_modules\mapdisp.py", line
785, in UpdateMap
for img in self.GetOverlay():
647, in GetOverlay
if os.path.isfile(overlay.mapfile) and
os.path.getsize(overlay.mapfile):
File "C:\GRASS6\Python25\lib\ntpath.py", line 283, in
isfile
st = os.stat(path)
TypeError
coercing to Unicode: need string or buffer, NoneType found
*Then everytime I press display map or Zoom In/Zoom Out I get the same
Window-Error and text in the command window.
My question is: is this an expected error/situation?
Thanks
Antonio
A
Hamish wrote:
> António wrote:
>> I have a location with a region with the following
>> characteristics:
>> When I try to add north arrow/Scale to the map I get a
>> ERROR-Window with the following:
>> Error: b.barscale does not work with a latitude-longitude
>> location
> A scale-bar simply does not & can not work with lat/lon.
> Distance scale is not the same on the x and y axes.
> Use d.grid instead.
> See the help page.
> (there was an idea to change the units to degrees/min/sec for
> lat/lon scalebars a while back but it hasn't been implemented
> yet)
>> And the following error is printed in the command output:
>> File
>> # close dialog
>> line
>> 785, in UpdateMap
>> line
>> 647, in GetOverlay
>> isfile
>> st = os.stat(path)
>> TypeError
>> Is this a bug or is this something that would be expected?
>> If it's a bug I will add to the trac
> all that extra noise isn't nice, it should give the error and
> quietly go away.
> Hamish
> __________ Information from ESET NOD32 Antivirus, version of virus signature database 4784 (20100118) __________
> The message was checked by ESET NOD32 Antivirus.
> http://www.eset.com
__________ Information from ESET NOD32 Antivirus, version of virus signature database 4785 (20100119) __________
http://www.eset.com
More information about the grass-windows
