[GRASS-windows] GUI with python scripts
Ned Horning
horning at amnh.org
Fri Jan 29 14:41:53 EST 2010
Hi -
I tried the most recent daily build for Window
(WinGRASS-6.4.SVN-r-40722-1-Setup.exe) and it appears as if something
has changed since I get a different error when running a Python script.
I still can not get a GUI to appear but when I run my test script using
the --ui flag I get the following error. Can anyone tell if this looks
like another bug or a user problem.
GRASS 6.4> python
F:\\AMNH\\WHRC_CarbonProject\\R_Project\\PercentCoverTutorial\\junk.py --ui
GRASS 6.4> Traceback (most recent call last):
File "c:/Program
Files/GRASS-64-SVN/etc/wxpython/gui_modules/menuform.py", line 1942, in
<module>
GrassGUIApp( grassTask( sys.argv[1] ) ).MainLoop()
File "c:/Program
Files/GRASS-64-SVN/etc/wxpython/gui_modules/menuform.py", line 334, in
__init__
xml.sax.parseString( getInterfaceDescription( grassModule ) ,
processTask( self ) )
File "c:/Program
Files/GRASS-64-SVN/etc/wxpython/gui_modules/menuform.py", line 1759, in
raise IOError, _("Unable to fetch interface description for command
'%s'.") % cmd
IOError: Unable to fetch interface description for command 'junk.py'.
All the best,
Ned
On 1/22/2010 10:17 AM, Glynn Clements wrote:
> Ned Horning wrote:
>> This is the output from g.gisenv:
>> > menuform.py: can't open file 'c:/Program': [Errno 2] No such file or
>> directory
> You'll have to either wait for a newer version or install GRASS into
> e.g. C:\GRASS.
> Someone seems to have read my comments about having the next release
> candidate install into the %ProgramFiles% directory, and decided to go
> one better and start installing the 6.4.0-SVN snapshots there.
> This won't work until the recent changes to the G_spawn* functions
> have been back-ported. The current 6.4.0 code is known not to work
> with spaces in $GISBASE. 6.5 should work (although based upon recent
> comments, MSys might need to be installed in C:\msys).
More information about the grass-windows
