[GRASS-windows] GUI with python scripts
Fri Jan 29 19:25:57 EST 2010
Ned Horning wrote:
> I tried the most recent daily build for Window
> (WinGRASS-6.4.SVN-r-40722-1-Setup.exe) and it appears as if something
> has changed since I get a different error when running a Python script.
> I still can not get a GUI to appear but when I run my test script using
> the --ui flag I get the following error. Can anyone tell if this looks
> like another bug or a user problem.
> IOError: Unable to fetch interface description for command 'junk.py'.
What do you get from:
	junk.py --interface-description
More information about the grass-windows mailing list
