[GRASS-windows] Imbedding in Windows GUI Application
WGPuckett
WGPuckett at aol.com
Sun Oct 3 12:55:50 EDT 2010
I need to begin development of an application that will run on WinXP and/or
Win7. One of the urgent needs for this application is to be able to display
panels with maps in 2.5D and 3D. From what I have found, GRASS is just
about the only open source software that generates a sophisticated 3D map.
Forgive me if I have missed this capability in reviewing the documentation
but it appears that GRASS is primarliy intended to work from a command level
scripting environment and not in a program environment. I wanted to confirm
this before I move on.
I primarily code in Java but if necessary I can develop in C# or C++. Is it
possible to utilize GRASS as an API from a Java, C# or C++ application in
a native Windows environment? If this is possible would someone direct me
to specific documentation and/or code examples?
I need to be able to display the maps from inside my Windows application and
control the maps from that application. So I need to be able to ask GRASS
to generate the map and pass it back to the code so that code can include
the map in a panel. I have written Windows applications using other mapping
API's in this fashion but none of those API's provide the 3D support that
GRASS does.
I appreciate any help in finding answers to my questions.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Imbedding-in-Windows-GUI-Application-tp5596563p5596563.html
Sent from the Grass - Win mailing list archive at Nabble.com.
More information about the grass-windows
