[GRASS-windows] Re: GRASS 6.4.0 in Windows XP
Thierry_
grass at muscardinus.be
Tue Sep 28 17:27:35 EDT 2010
Maciej Sieczka wrote:
> Does g.proj work ok from the command line though? If not, check if this
> is not the same issue as in
> http://osgeo-org.1803224.n2.nabble.com/lots-of-The-application-failed-to-initialize-properly-in-6-4-0-on-Windows-td5521511.html#a5571695.
No. Running g.proj from the command line gave a another error. "cannot find
ordinal 284 in SSLEAY32.dll"
I tried your suggestions in the other post, but that did not solve the
problem either.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/GRASS-6-4-0-in-Windows-XP-tp5568515p5581329.html
Sent from the Grass - Win mailing list archive at Nabble.com.
More information about the grass-windows
