[GRASS-windows] Re: GRASS 6.4.0 in Windows XP
    Hanlie Pretorius
    hanlie.pretorius at gmail.com
    Thu Sep 30 02:46:38 EDT 2010
> Date: Tue, 28 Sep 2010 14:27:35 -0700 (PDT)
> From: Thierry_ <grass at muscardinus.be>
> Subject: [GRASS-windows] Re: GRASS 6.4.0 in Windows XP
> To: grass-windows at lists.osgeo.org
> Message-ID: <1285709255161-5581329.post at n2.nabble.com>
> Content-Type: text/plain; charset=us-ascii
> Maciej Sieczka wrote:
>> Does g.proj work ok from the command line though? If not, check if this
>> is not the same issue as in
>> http://osgeo-org.1803224.n2.nabble.com/lots-of-The-application-failed-to-initialize-properly-in-6-4-0-on-Windows-td5521511.html#a5571695.
> No. Running g.proj from the command line gave a another error. "cannot find
> ordinal 284 in SSLEAY32.dll"
I've had a similar problem and fixed it by installing openssl.
(http://www.openssl.org/related/binaries.html)
More information about the grass-windows
