[GRASS-windows] Fwd: Re: [GRASS-user] Problem Script: "from
collections import deque"
Johannes Radinger
JRadinger at gmx.at
Mon Feb 21 05:13:11 EST 2011
Hello GRASS-Windows people,
do you know what is the problem and how to solve it?
I just need a working GRASS Version with the r.stream* module
for my Windows 7, but it seems that my V6.5SVN is broken.
I need to work with python scripts...
see message below for a more detailed description of my problem
/johannes
-------- Original-Nachricht --------
Datum: Fri, 18 Feb 2011 21:58:38 +0000
Von: Glynn Clements <glynn at gclements.plus.com>
An: "Johannes Radinger" <JRadinger at gmx.at>
CC: grass-user at lists.osgeo.org
Betreff: Re: [GRASS-user] Problem Script: "from collections import deque"
Johannes Radinger wrote:
> It seems there is a problem when I am trying to run a python script in
> GRASS GIS (every script I tried)...
> ...the error is:
> File "C:\GRASS6.5.SVN\Python25\lib\threading.py", line 13,
> in <module>
> ImportError: No module named collections
> But if I try to run the import command directly from the IDLE python
> shell (from collections import deque) it seems that the module is
> existing and loaded properly.
> I am working on Windows 7 with GRASS 6.5SVN and Pyhon 2.6.5
> What is there the problem?
GRASS "bundles" Python 2.5. Even when this works, it doesn't work
correctly.
Unfortunately, there isn't a simple option for running GRASS on
Windows at the moment. The official Windows packages for GRASS are
quite badly broken, and doing it yourself is a lot of work.
grass-user mailing list
http://lists.osgeo.org/mailman/listinfo/grass-user
GMX DSL Doppel-Flat ab 19,99 Euro/mtl.! Jetzt mit
gratis Handy-Flat! http://portal.gmx.net/de/go/dsl
More information about the grass-windows
