[GRASS-windows] Re: [GRASS-user] Problem Script: "from collections import deque"
Luigi Ponti lponti at inbox.com
Mon Feb 21 17:29:59 EST 2011
Dear Glynn,
> -------- Original-Nachricht --------
> Datum: Fri, 18 Feb 2011 21:58:38 +0000
> Von: Glynn Clements <glynn at gclements.plus.com>
> An: "Johannes Radinger" <JRadinger at gmx.at>
> CC: grass-user at lists.osgeo.org
> Betreff: Re: [GRASS-user] Problem Script: "from collections import deque"
> Unfortunately, there isn't a simple option for running GRASS on
> Windows at the moment. The official Windows packages for GRASS are
> quite badly broken, and doing it yourself is a lot of work.
I did notice that.
I just wonder how much responsibility do I carry as a GRASS and windows
user.
What is the plan -- in terms of GRASS road map? In the development stage
immediately prior to WinGRASS-6.4.0 release, things were getting better
as never before and at a fast pace. Then things seem to have somewhat
fallen apart.
Probably the windows user base -- I mean, myself -- has very low
programming skills, and hence is unable to help move things forward.
I am trying to understand if there is something I can help with given my
limited skills and time available.
Thanks for posting on the grass-windows ML, and for any hint,
Luigi
More information about the grass-windows mailing list
