[GRASS-windows] Re: [GRASS-user] Problem Script: "from collections import deque"
Luigi Ponti lponti at inbox.com
Tue Feb 22 04:16:03 EST 2011
On 22/02/2011 01:45, Glynn Clements wrote:
> Luigi Ponti wrote:
>>> Unfortunately, there isn't a simple option for running GRASS on
>>> Windows at the moment. The official Windows packages for GRASS are
>>> quite badly broken, and doing it yourself is a lot of work.
>> I did notice that.
>> Probably the windows user base -- I mean, myself -- has very low
>> programming skills, and hence is unable to help move things forward.
> This has always been the problem for GRASS. The developers don't
> generally develop for Windows, while those using GRASS on Windows
> generally aren't developers.
> However, this particular issue isn't a programming issue, but a
> packaging issue. If you want to use Python for scripting GRASS on
> Windows, the best solution is to delete the bundled version of Python
> 2.5 from the GRASS installation, install Python and the required
> add-ons (wxPython, NumPy, PyWin32) from their official installers,
> then edit the GRASS start-up script to remove any references to the
> bundled version.
Thanks.
I added a note here:
http://grass.osgeo.org/wiki/GRASS_and_Python#MS-Windows
Please, advice if it isn't appropriate.
Luigi
URL: http://lists.osgeo.org/pipermail/grass-windows/attachments/20110222/d11eb665/attachment.html
More information about the grass-windows mailing list
