[GRASS-windows] error with r.watershed.ram.exe
JM Delgado jdelgado at gfz-potsdam.de
Fri Feb 25 05:38:28 EST 2011
Dear all,
I can't run r.watershed on my windows server, but I can run the exact
same command in my personal linux laptop.
The specifications and details are below. I am afraid that the package I
installed is not the correct one for a server. Let me know what you think.
Should I report a bug?
greetings
ze
Machine:
Mainboard: Supermicro X8DAi
CPU: 2x Intel® Xeon(tm) Nehalem Processor EP QC W5590, 3.33 GHz, Socket 1366, 8MB Cache, 1333MHz
Chipset: Intel® 5520 (Tylersburg)
RAM: 48GB (6x 8GB) DDR3 / PC1333
OS: Windows Server 2008 R2 Enterprise Server SP1 (x64)
Installation:
WinGRASS-6.4.0-1-Setup.exe 04-Sep-2010 10:01 / Stand-alone Installer package by Nielsen&  Kudrnovsky
GRASS 6.4.0  - Error: r.watershed.ram.exe:
GRASS Report:
Unterprozess fehlgeschlagen mit dem Fehlercode -1073741571
Windows Report:
Faulting application name: r.watershed.ram.exe, version: 0.0.0.0, time stamp: 0x4c815f53
Faulting module name: r.watershed.ram.exe, version: 0.0.0.0, time stamp: 0x4c815f53
Exception code: 0xc00000fd
Fault offset: 0x00008484
Faulting process id: 0x188c
Faulting application start time: 0x01cbd4d24c126c0c
Faulting application path: e:\GRASS-64\etc\r.watershed.ram.exe
Faulting module path: e:\GRASS-64\etc\r.watershed.ram.exe
Report Id: 9f2cfad8-40c5-11e0-b3f1-003048f9b620
José Miguel Delgado
Section 5.4 Hydrology
Tel.: +49 331 288 1596
Fax: +49 331 288 1570
Email: jdelgado at gfz-potsdam.de
Helmholtz-Zentrum Potsdam
Deutsches GeoForschungsZentrum GFZ
(GFZ German Research Centre for Geoscience)
Stiftung des öff. Rechts Land Brandenburg
Telegrafenberg, 14473 Potsdam
Type: text/x-vcard
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-windows/attachments/20110225/0fae3939/jdelgado.vcf
More information about the grass-windows mailing list
