[GRASS-windows] error with r.watershed.ram.exe
Markus Neteler neteler at osgeo.org
Sun Feb 27 05:16:38 EST 2011
On Fri, Feb 25, 2011 at 11:38 AM, JM Delgado <jdelgado at gfz-potsdam.de> wrote:
> Dear all,
> I can't run r.watershed on my windows server, but I can run the exact same
> command in my personal linux laptop.
> The specifications and details are below. I am afraid that the package I
> installed is not the correct one for a server. Let me know what you think.
> Should I report a bug?
Please post the output of
g.region -p
Perhaps too many raster cells?
Markus
> greetings
> ze
> Machine:
> Mainboard: Supermicro X8DAi
> CPU: 2x Intel® Xeon(tm) Nehalem Processor EP QC W5590, 3.33 GHz, Socket
> 1366, 8MB Cache, 1333MHz
> Chipset: Intel® 5520 (Tylersburg)
> RAM: 48GB (6x 8GB) DDR3 / PC1333
> OS: Windows Server 2008 R2 Enterprise Server SP1 (x64)
> Installation:
> WinGRASS-6.4.0-1-Setup.exe 04-Sep-2010 10:01 / Stand-alone Installer package
> by Nielsen&  Kudrnovsky
> GRASS 6.4.0  - Error: r.watershed.ram.exe:
> GRASS Report:
> Unterprozess fehlgeschlagen mit dem Fehlercode -1073741571
> Windows Report:
> Faulting application name: r.watershed.ram.exe, version: 0.0.0.0, time
> stamp: 0x4c815f53
> Faulting module name: r.watershed.ram.exe, version: 0.0.0.0, time stamp:
> 0x4c815f53
> Exception code: 0xc00000fd
> Fault offset: 0x00008484
> Faulting process id: 0x188c
> Faulting application start time: 0x01cbd4d24c126c0c
> Faulting application path: e:\GRASS-64\etc\r.watershed.ram.exe
> Faulting module path: e:\GRASS-64\etc\r.watershed.ram.exe
> Report Id: 9f2cfad8-40c5-11e0-b3f1-003048f9b620
> José Miguel Delgado
> Section 5.4 Hydrology
> Tel.: +49 331 288 1596
> Fax: +49 331 288 1570
> Email: jdelgado at gfz-potsdam.de
> Helmholtz-Zentrum Potsdam
> Deutsches GeoForschungsZentrum GFZ
> (GFZ German Research Centre for Geoscience)
> Stiftung des öff. Rechts Land Brandenburg
> Telegrafenberg, 14473 Potsdam
> grass-windows mailing list
> grass-windows at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-windows
More information about the grass-windows mailing list
