[GRASS-windows] Re: Zonal Statistics - min
Markus Neteler neteler at osgeo.org
Thu Mar 17 21:01:22 EDT 2011
On Thu, Mar 17, 2011 at 10:41 PM, rasmus borgstrøm <rb at gras.ku.dk> wrote:
> Hi
> I have installed winGRASS 7 and tried to calculate the zonal statistics, but
> I cannot seem to get the results.
> I tried this:
> r.univar -g -e -t map=MOD02QKM zones=fields.10m output=out2>fields_stats.txt
> I assume this will write the zonal stat to the .txt file, but I cannot seem
> to access/find the txt file. ?!
You are writing the output to out2 (maybe better call it out2.txt or
even better stats.txt).
It should be in the current directory. The >fields_stats.txt will not gain
anything since output= is used and not set to output=- (stdout).
I guess you are already there.
Markus
More information about the grass-windows mailing list
