[GRASS-windows] Re: Zonal Statistics - min
Rasmus Borgstrøm
Rb at gras.ku.dk
Fri Mar 18 04:15:17 EDT 2011
Hi Markus
Yes you're right. Solved the output issue. Thanks!
Next problem is then how to access the minimum value in the stats.txt
file. Can you guide me in a direction or to script examples
(unfortunately I didn't find any in your book)?
I would like have the minimum value used in a r.mapcalc DOS_MODIS =
MODISIMAGE - STATS.TXT(%MIN%)
Basically what I am trying to is a Dark Objection Subtraction of a
MODIS timeserie, so if you have ideas for other approaches for this
please let me know.
Best regards,
Rasmus
To:rasmus borgstrøm<rb at gras.ku.dk>
CC:<grass-windows at lists.osgeo.org>
Date: 18-03-2011 02:01
Subject: Re: [GRASS-windows] Re: Zonal Statistics - min
On Thu, Mar 17, 2011 at 10:41 PM, rasmus borgstrøm <rb at gras.ku.dk>
wrote:
> Hi
> I have installed winGRASS 7 and tried to calculate the zonal
statistics, but
> I cannot seem to get the results.
> I tried this:
> r.univar -g -e -t map=MOD02QKM zones=fields.10m
output=out2>fields_stats.txt
> I assume this will write the zonal stat to the .txt file, but I
cannot seem
> to access/find the txt file. ?!
You are writing the output to out2 (maybe better call it out2.txt or
even better stats.txt).
It should be in the current directory. The >fields_stats.txt will not
gain
anything since output= is used and not set to output=- (stdout).
I guess you are already there.
Markus
URL: http://lists.osgeo.org/pipermail/grass-windows/attachments/20110318/5d730e49/attachment.html
More information about the grass-windows
