[GRASS-windows] Re: Zonal Statistics - min
Markus Neteler neteler at osgeo.org
Fri Mar 18 04:29:26 EDT 2011
Hi Rasmus,
On Fri, Mar 18, 2011 at 9:15 AM, Rasmus Borgstrøm <Rb at gras.ku.dk> wrote:
>  Hi Markus
> Yes you're right. Solved the output issue. Thanks!
excellent.
  Next problem is then how to access the minimum value in the stats.txt
> file. Can you guide me in a direction or to script examples (unfortunately I
> didn't find any in your book)?
In general, see page 49 for the usage of the eval function (I am not quite
sure that this works on
Windows, though). Shell script style (no -t):
eval `r.univar -g -e map=MOD02QKM output=-`
BUT: since you want zonal statistics eval will fail since the same variable
names are
printed for each zone.
I am afraid that you have to continue with -t (table style) and perhaps
consider the (file) output
as CSV table. Then access by row/column to feed the subsequent script.
Maybe other list member have an idea how to do that in Windows (I would use
cut/grep/etc).
Markus
> I would like have the minimum value used in a r.mapcalc DOS_MODIS =
> MODISIMAGE - STATS.TXT(%MIN%)
> Basically what I am trying to is a Dark Objection Subtraction of a MODIS
> timeserie, so if you have ideas for other approaches for this please let me
> know.
> Best regards,
> Rasmus
>     *From: * Markus Neteler <neteler at osgeo.org> *To:* rasmus borgstrøm<
> rb at gras.ku.dk> *CC:* <grass-windows at lists.osgeo.org> *Date: * 18-03-2011
> 02:01 *Subject: * Re: [GRASS-windows] Re: Zonal Statistics - min
> On Thu, Mar 17, 2011 at 10:41 PM, rasmus borgstrøm <rb at gras.ku.dk> wrote:
> > Hi
> > I have installed winGRASS 7 and tried to calculate the zonal statistics,
> but
> > I cannot seem to get the results.
> > I tried this:
> > r.univar -g -e -t map=MOD02QKM zones=fields.10m
> output=out2>fields_stats.txt
> > I assume this will write the zonal stat to the .txt file, but I cannot
> seem
> > to access/find the txt file. ?!
> You are writing the output to out2 (maybe better call it out2.txt or
> even better stats.txt).
> It should be in the current directory. The >fields_stats.txt will not gain
> anything since output= is used and not set to output=- (stdout).
> I guess you are already there.
> Markus
URL: http://lists.osgeo.org/pipermail/grass-windows/attachments/20110318/9eb644a1/attachment.html
More information about the grass-windows mailing list
