[GRASS-windows] Creating Python scripts that call GRASS functionality from outside
Fri Dec 21 05:30:24 PST 2012
Brian Sanjeewa Rupasinghe wrote:
> I just installed GRASS 6.4.3svn and Python 2.7.3 in Windows 7. I need to
> call GRASS functions from outside GRASS. I set the environment variables
> given
> in the grasswiki except:
> GISRC= C:\Documents and settings\user\.grassrc6
> Because i cannot find this .grassrc6 in the given path or in any other
> path.
A suitable should be created the first time you run GRASS.
Alternatively, you can create the file yourself, e.g.:
GISDBASE: /opt/grass-data
LOCATION_NAME: spearfish57
MAPSET: user1
GRASS_DB_ENCODING: ascii
> However with other variables, i tried to use from grass.lib
> importgrass in Python27 IDLE. Then it gives an error. I think the
> variables are
> not set correctly. Could somebody help me to sort this out?
If GISRC doesn't refer to a valid settings file, nothing will work.
More information about the grass-windows mailing list
