[GRASS-windows] syntax for v.db.select run by grass.run_command
Liu, Huili HLiu at ap.org
Tue Mar 20 16:25:35 EDT 2012
> 2. The ordinal 63 could not be located in the dynamic link libexpat.dll.
I checked the %WINDIR%\system32 in Windows XP and I could not find this dll file at all. The popup error shows "... could not be located in dynamic link library libexpat.dll".
Thanks,
Willie
-----Original Message-----
From: neteler.osgeo at gmail.com [mailto:neteler.osgeo at gmail.com] On Behalf Of Markus Neteler
Sent: Saturday, March 17, 2012 5:41 PM
To: Liu, Huili
Cc: grass-windows at lists.osgeo.org
Subject: Re: [GRASS-windows] syntax for v.db.select run by grass.run_command
On Tue, Mar 13, 2012 at 9:38 PM, Liu, Huili <HLiu at ap.org> wrote:
> Thanks Markus.
> I uninstalled the old version and installed GRASS 6.4.2 from your link but I got two errors:
> 1. ERROR: G_getenv(): Variable LOCATION_NAME not set
Strange no idea here. How do you start it?
You have likely an old "libexpat.dll" in your directory %WINDIR%\system32 (or %WINDIR%\sysWOW64). Try to rename that file (or delete after backup).
Then winGRASS should work.
Added as new FAQ: http://grass.osgeo.org/wiki/WinGRASS_errors
Markus
The information contained in this communication is intended for the use
of the designated recipients named above. If the reader of this
communication is not the intended recipient, you are hereby notified
that you have received this communication in error, and that any review,
dissemination, distribution or copying of this communication is strictly
prohibited. If you have received this communication in error, please
notify The Associated Press immediately by telephone at +1-212-621-1898
and delete this email. Thank you.
[IP_US_DISC]
msk dccc60c6d2c3a6438f0cf467d9a4938
More information about the grass-windows mailing list
