[GRASS-windows] syntax for v.db.select run by grass.run_command
    Markus Neteler
    neteler at osgeo.org
    Sat Mar 31 15:06:42 EDT 2012
Hi Willie,
On Tue, Mar 13, 2012 at 9:38 PM, Liu, Huili <HLiu at ap.org> wrote:
> 2. The ordinal 63 could not be located in the dynamic link libexpat.dll.
> I setup Environment Variable for LOCATION_NAME on Windows but the error 1 is still showed up. I checked libexpat.dll but I could not find it anywhere. It should come from the installation of GRASS 6.4.2, right?
I think it comes from the GDAL installation:
http://trac.osgeo.org/gdal/wiki/BuildingWithMinGW
--> expat
Perhaps you could just get it from one of these DLL sites and
put it into the DLL directory?
Markus
Markus
More information about the grass-windows
