[GRASS-windows] Problem with installation instructions for GRASS on MS-Windows with Cygwin (winGRASS)
Angelo Paone
angelo.paone1 at gmail.com
Thu Feb 28 17:20:54 PST 2013
Dear All,
I am trying to install grass64, gdal1.6, and tcltk-grass-8.4.7-1 throug the
instraction of the cygwin installation setup.exe, I do everything as in
written instaraction of the following web page:
http://grass.osgeo.org/grass64/binary/mswindows/cygwin/
but I do not get access to the URL for downloading the packages * **
http://grass.osgeo.org/grass64/binary/mswindows/cygwin/*
in the set up file I have the following information:
2013/02/28 08:45:42 Starting cygwin install, version 2.774
2013/02/28 08:45:42 User has backup/restore rights
2013/02/28 08:45:42 io_stream_cygfile: fopen(/etc/setup/net-proxy-host)
failed 2 No such file or directory
2013/02/28 08:45:42 io_stream_cygfile: fopen(/etc/setup/net-proxy-port)
2013/02/28 08:45:42 io_stream_cygfile: fopen(/etc/setup/extrakeys) failed 2
fopen(/etc/setup/chooser_window_settings) failed 2 No such file or directory
2013/02/28 08:45:42 Current Directory:
C:\cygwin\home\bob\cygwin\Cygwin_installation
2013/02/28 08:45:42 Could not open service McShield for query, start and
stop. McAfee may not be installed, or we don't have access.
2013/02/28 08:45:47 source: network install
2013/02/28 08:45:49 root: C:\cygwin binary system
2013/02/28 08:46:04 Ending cygwin install,
can you please tell me what I can do for download the above packages.
appreciate if you reply to me
Angelo
Angelo Paone
Research Professor
Post-Doctoral Research Fellow
Marie Curie Fellow
PhD, MSc, BSc
Pusan Natioanl University
Department of Earth Science
30, Jangjeon-dong, Geumjeong-gu
Busan, Republic of Korea
Tel. +82-51-510-2987
URL: <http://lists.osgeo.org/pipermail/grass-windows/attachments/20130228/f63c6cf4/attachment.html>
More information about the grass-windows
