[gvSIG-devel] OSM 429 status error
Mario Carrera mcarrera at gvsig.com
Mon Apr 6 00:16:30 PDT 2020
Hi Betto,
I haven't understood your problem concretely.
If you needed to download gvSIG as developer here you have more
information: http://www.gvsig.com/en/products/gvsig-desktop/development
If the problem was related to gvSIG installation as user, you can
download it from the official website:
- gvSIG 2.5: http://www.gvsig.com/en/products/gvsig-desktop/downloads
- gvSIG 2.4:
http://www.gvsig.com/en/products/gvsig-desktop/previous-versions
There are 2 distributions: installable and portable versions. For
installable version you can follow the wizard, and for portable version
you only have to unzip the zip file.
If you were referring to OSM tiles in gvSIG, in gvSIG 2.x versions OSM
must be used on EPSG 3857 views. From 3.x versions it will be
reprojected and you will be able to use it on other reference systems.
To load OSM tiles you have to access to "Add layer" window, then "OSM"
tab, and you can select "Mapnik" or "OSM Black&Wight".
Best regards,
   Mario
El 4/4/20 a las 18:28, Betto McRose [icarus] escribió:
> hi, I'm new as you may already notice
> I started a course on using gvSIG-desktop and now I'm, so...
> first I manually installed 2.5, then today I got it from arch
> community, version 2.4
> looked up for solutions, but nothing found, except for this link
> https://help.openstreetmap.org/questions/72426/error-429-in-mapinfo-with-osm-tile-server
> any ideas on when this would be fixed ?
> [icarus]
> https://about.me/mcrose
> <https://about.me/mcrose?promo=email_sig>
> Betto McRose
> Java/JavaEE Developer
> gvSIG-Desktop-Devel mailing list
> gvSIG-Desktop-Devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gvsig-desktop-devel
*Mario Carrera*
gvSIG Association / Asociación gvSIG
http://www.gvsig.com <http://www.gvsig.com/>
Antes de imprimir este e-mail piense bien si es necesario hacerlo.
AVISO LEGAL: Este mensaje y sus archivos adjuntos van dirigidos
exclusivamente a su destinatario, pudiendo contener información
confidencial sometida a secreto profesional. No está permitida su
comunicación, reproducción o distribución sin la autorización expresa de
la Asociación gvSIG. Si usted no es el destinatario final, por favor
elimínelo e infórmenos por esta vía.
PROTECCIÓN DE DATOS: De conformidad con lo dispuesto en las normativas
vigentes en protección de datos personales, el Reglamento (UE) 2016/679
de 27 de abril de 2016 (GDPR) y la Ley Orgánica (ES) 15/1999 de 13 de
diciembre (LOPD), le informamos que los datos personales y dirección de
correo electrónico, recabados del propio interesado o de fuentes
públicas, serán tratados bajo la responsabilidad de la /Asociación gvSIG
/para el envío de comunicaciones sobre nuestros productos y servicios y
se conservarán mientras exista un interés mutuo para ello. Los datos no
serán comunicados a terceros, salvo obligación legal. Le informamos que
puede ejercer los derechos de acceso, rectificación, portabilidad y
supresión de sus datos y los de limitación y oposición a su tratamiento
dirigiéndose enviando un mensaje al correo electrónico a info at gvsig.com
<mailto:info at gvsig.com>. Si considera que el tratamiento no se ajusta a
la normativa vigente, podrá presentar una reclamación ante la autoridad
de control en www.agpd.es <http://www.agpd.es/>.
URL: <http://lists.osgeo.org/pipermail/gvsig-desktop-devel/attachments/20200406/2d01ad34/attachment.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gvsig-desktop-devel/attachments/20200406/2d01ad34/attachment.jpe>
More information about the gvSIG-Desktop-Devel mailing list
